Sorting by date/Office 2010
narrowgauge
I have a form in Word 2010 that contains a date field. Wishing to sort by date I imported the form into Excel 2010 only to find that Excel doesn't know how to handle 19th century dates. Anyone have any ideas on how I can achieve the sort?
TIA
6 REPLIES 6
Mav
Fixes: 515
Re: Sorting by date/Office 2010
I remember reading somewhere that the free LibraOffice suite can handle pre-1900 dates if that may help.
Forum Moderator and Customer
HPsauce
Depends on the format of the date in Word I guess, just write your own macro to convert it to yyyymmdd as a number.
Bit more work if you're going BC of course.  Wink
MrT
In Excel, if your dates are input in the format dd/mm/yy you could format the dates column as "Date 2001-03-14" or "Custom yyyy-mm-dd". The data should then sort correctly - it does in Excel 2007 anyway.
narrowgauge
Quote from: MrT
Tried this. Either way it just sorts the 20th century dates and ignores the earlier ones. Sad
Oldjim
Resting Legend
Fixes: 63
This explains how to get round it http://boards.straightdope.com/sdmb/showthread.php?t=333461 but it isn't nice
narrowgauge
Sometimes it is possible to be too clever. Sad
I took the approach of importing the table into Excel because a few years ago I wanted a table with numbered rows and that is what I was advised. Now, I remembered form/sorting/Excel and finished up here.
What I should have done is, in Word, clicked on layout/sort and choose the parameters, which did exactly what I wanted. Grin
Thanks to those who replied. Smiley
