Some help please (Specific DLL's)
- Some help please (Specific DLL's)
20-12-2009 6:37 PM
Now the consensus is that they are "standard" windows ones But I am begging to differ. They are specific to Virtual C++ 8 (I think) and are not normally included on a standard install.
Neither my Wine install or my XP sp3 VM had them so I thought I would throw it open a bit more,
Re: Some help please (Specific DLL's)
20-12-2009 7:02 PM
20-12-2009 7:08 PM
Updated poll.
20-12-2009 7:37 PM
Quote They are specific to Virtual C++ 8 (I think)
I'm fairly sure that they are the Visual Studio 2008 replacements for the C Runtime that used to be provided through msvcrt.dll. I would have thought that since msvcrt was part of a standard install you would expect them to be part of a Win 7 install and possibly included in updates for XP and Vista...
20-12-2009 7:47 PM
20-12-2009 7:50 PM
I have also checked in Windows 7 Ultimate RC where I definitely didn't install them and they are both there
20-12-2009 7:54 PM
20-12-2009 11:27 PM
As far as I can tell they are neither dynamic or libraries...
20-12-2009 11:36 PM
22-12-2009 11:59 AM
I don't know anthything about these dlls but would wouldn't they be required for use by any applications that were compiled with Virtual C++?
A little search and it seems that Lavasoft (Ad-Aware) requires them, at least. I have that installed.
Hope that helps.
Forum Moderator and Customer
22-12-2009 12:15 PM
As I said WIne doesn't have them installed and my XP VM didn't have them, but I appear to be in the minority
22-12-2009 4:27 PM
