Snipping tool
- Re: Snipping tool
Snipping tool
24-01-2011 5:13 PM
p.s the OS is Vista Home Premium
Re: Snipping tool
24-01-2011 5:41 PM
If you Google "sniping tool not working",there are many suggestions, I hope there is something that helps.
Re: Snipping tool
24-01-2011 11:35 PM
Re: Snipping tool
25-01-2011 7:17 AM
Re: Snipping tool
25-01-2011 10:15 AM
If you cant resolve on here, try PC Advisor forum their are a good many knowledge people there. You would need to register before posting a question
Re: Snipping tool
25-01-2011 2:22 PM
Thanks anniesboy - I will try them too.
Your are both very kind.
Re: Snipping tool
25-01-2011 4:12 PM
Re: Snipping tool
25-01-2011 4:19 PM
Re: Snipping tool
25-01-2011 4:33 PM
1. Click the Start button
2. From the Start Menu, Click All programs followed by Accessories
3. In the Accessories menu, Right Click on the Command Prompt option
4. From the drop down menu that appears, Click on the 'Run as administrator' option
5. If you have the User Account Control (UAC) enabled, you will be asked for authorization prior to the command prompt opening. You may simply need to press the Continue button if you are the administrator or insert the administrator password etc.
6. In the Command Prompt window, type: sfc /scannow and then press Enter
7. A message will appear stating that 'The system scan will begin'
8. Be patient because the scan may take some time
9. If any files require replacing SFC will replace them. You may be asked to insert your Vista DVD for this process to continue
10. If everything is okay you should, after the scan, see the following message "Windows resource protection did not find any integrity violations"
11. After the scan has completed, close the command prompt window, restart the computer and check.
as been suggested on another forum that I run a scan
Re: Snipping tool
25-01-2011 4:38 PM
Re: Snipping tool
25-01-2011 4:42 PM
Re: Snipping tool
25-01-2011 4:46 PM
also have you tried sending something direct from another program such as Word
Re: Snipping tool
25-01-2011 6:20 PM
1 Hide instruction text
2 Always copy snips to clipboard
3 Include URL below snips (HTML only)
4 Prompt to save snips before exiting
5 Display icon in the Quick launch toolbar
6 Show Screen overlay when Snipping Tool is active
7 Show selection ink after snips are captured
they are all ticked except 1 and 5.
Re: Snipping tool
25-01-2011 6:27 PM
(no boxes were open) Please help me someone!
Re: Snipping tool
25-01-2011 6:31 PM
