SSID for a RPi
- SSID for a RPi
SSID for a RPi
11-11-2014 7:24 PM
I'm struggling to set up my wifi on a RPi, I have to enter my SSID, is this the string that shows on my PC wifi connection, ie PlusnetwirelessB7CCB8 or is it just the B7CCB8 or have I got it completely wrong
I'm trying to follow these instructions http://pingbin.com/2012/12/setup-wifi-raspberry-pi/
Paul
Paul
2 REPLIES 2
Re: SSID for a RPi
11-11-2014 7:27 PM
its the whole string
you can also use wicd which has a "gui" to select the wifi.
I did that on mine but it does load later in the start up than manual setting of the details.
Re: SSID for a RPi
11-11-2014 9:02 PM
Thanks, that explains why I wasn't getting anywhere, I was just using the B7CCB8 bit
