Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
tevo5
Re: Running OpenWRT on the Plusnet Hub One (& BT Home Hub 5a)
@bill888
had another go, this time, hh5a.nanddump size 131072kb
will try to install sysupgrade without calibration backup, got nothing to lose.
will post result.
tevo5
jimbof
You are probably in for a world of pain.
The installer probably won't work - one of the steps it does is back up the calibration data itself to a temp location, before erasing the entire flash chip and then restoring the calibration data.  If the calibration backup doesn't seem successful it doesn't usually progress.  So you might have to modify the installer script to make it work despite no calibration data.
If you do get it to install without having backed up the calibration data, then you will probably the at least the following issues:
No MAC address - the MAC addresses at least are stored in there.
Poor 5GHz performance - The ath10k wireless has calibration in there (5GHz)
Searching the LEDE / openwrt source for the string caldata will shed more light.  If you can live without wifi and replace the caldata yourself then you might be able to make it work.  (this link will give you a quick idea of the kind of things: https://lists.openwrt.org/pipermail/openwrt-devel/2015-June/033910.html )
I have a unit I couldn't use as too many flash errors - just binned it as these change hands for so little money 2nd hand it is hardly worth the hassle.
jimbof
Here is a quick video I filmed of how to crack the case without damaging it on an HH5A
tevo5
Thanks to all who replied.
You were spot on. Its now in the bin. tried with a donated plusnet hub & install of openwrt went flawlessly.
Not used in anger,  i have draytek 2820 in use, but will try out when time permits.
thanks again.
tevo5.
Balzat
I have a problem
After sending u-boot via serial, and run putty I press enter several times and getting
ROM VER: 1.1.4
CFG 04
UART
instead
BTHOMEHUBV5A #
bill888
Champion
Fixes: 40
Does your hub still boot normally into BT stock firmware, or is it stuck in CFG 04 UART mode even when you don't connect BOOT_SEL2 to Ground?
See also:
http://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=148
Balzat
Still boot normally into BT stock firmware
bill888
Champion
Fixes: 40
What type of serial adaptor are you using?
I presume you are using Windows.  What COM port is assigned to the adaptor?
http://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=138&start=20#p1203
Balzat
Yes I'm using Windows
I use adaptor with chip FT232RL setted to COM1
adaptor
I use that command:
type openwrt-lantiq-bthomehubv5a_ram-u-boot.asc > \\.\COM1
bill888
Champion
Fixes: 40
FT232RL appears to have additional RTS and CTS pins.  Have you tried connecting them together to see if it makes any difference?
You may wish to ask if anyone has successfully used the RT232RL in this forum:
http://openwrt.ebilan.co.uk/viewforum.php?f=14
Balzat
I installed Debian, and the problem is solved
I installed openwrt on the router, and I can connect to the router via ssh
Now I have another problem, I can not connect to the Internet, and I can not run the web interface.
bill888
Champion
Fixes: 40
LUCI web interface should appear when you point a web browser to default 192.168.1.1 when using r48886 or r49377. If you are using Windows, try using Internet Explorer.  On rare occasions, I have had issues with Chrome failing to bring up the LUCI login page.  Try also  https://192.168.1.1
Balzat
I tried to open the web interface in Opera and it was a problem
Now everything works as it should
tstaddon
Re: Running OpenWRT on the Hub One/Home Hub 5a
Hi
Out of curiosity, is the OpenWRT firmware something Plusnet might ever consider picking up and offering? For now I'm happy daisychaining the Hub One to a router I have more low level control over, but I would quite like the ability to control it at a far more granular level.
thedyes0
Anyone know if OpenWRT on the Plusnet Hub 1 has the ability to enable/disable bridge mode and/or enable/disable NAT?
