Ring doorbell - connecting to 2.4ghz
- Ring doorbell - connecting to 2.4ghz
- « Previous
- 1
- 2
- Next »
Re: Ring doorbell - connecting to 2.4ghz
26-11-2025 8:47 PM
I have tried this and it didn’t work 😩
26-11-2025 8:48 PM
Is that even though your router is ‘dual band’?
26-11-2025 8:49 PM - edited 26-11-2025 8:52 PM
@Grace3 You only need to turn the 5Ghz band off whilst you connect the bell- after factory resetting it, and then turn it back on once the bell is working.
BTW - It is a good idea to either 'tag' or mention the person you are replying to in your reply.
- « Previous
- 1
- 2
- Next »
