Ring doorbell - connecting to 2.4ghz
Grace3
Re: Ring doorbell - connecting to 2.4ghz
I have tried this and it didn’t work 😩
Grace3
Is that even though your router is ‘dual band’?
Fixes: 357
@Grace3 You only need to turn the 5Ghz band off whilst you connect the bell- after factory resetting it, and then turn it back on once the bell is working.
BTW - It is a good idea to either 'tag' or mention the person you are replying to in your reply.
