Reverse DNS for email server
chummleywarner
Hi Folks,
I need my reverse DNS name changing to my email server + domain name, since every now and then I keep getting my domain blocked by spanhus ect.
I have just got blocked by spamRATS, and to get unblocked, It is now a requirement that my reverse DNS is solved before they will unblock me. Sad
This means I can no longer send email from my mail server, and only found out when I came to do so..
I have A records and PTR records set already, I believe that it's just the reverse DNS.
and needs to be in the form of mail.yourdomain.com
Can someone please help?
Best regards,
Neil.
4 REPLIES 4
MatthewWheeler
Fixes: 503
Re: Reverse DNS for email server
Morning @chummleywarner
If you can drop me a PM with your username and what you want the rDNS set to I'll get that raised for you
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
chummleywarner
Good Morning  MatthewWheeler!
Thank you for taking the time to look at my request.
Can I please get the rDNS set to
mail.fletcher-baggaley.co.uk
Thanks in advance.
Regards,
Neil.
adamwalker
Fixes: 223
Hiya Neil, Matt is off today so I've picked this up for you. I've raised a task over to our netops team for that and should get a response in the next day or two. I'll reply back when I see that come through.
 Adam Walker
adamwalker
Fixes: 223
Hi there, this should be sorted now, do shout up if there's anything else I can do for you.
 Adam Walker
