VPN
ChrisD2
VPN
Hi all,
I use the android built in VPN to connect to my home network when away.
Simple, fixed ip at home, open up my settings go to VPN click connect and it should work.
If I'm on a WiFi in a cafe for example the VPN connects no trouble. If I'm using my mobile signal it won't connect.
I was with EE, everything worked fine. I then changed to ID mobile, they believe there is nothing wrong. So the only thing left for me really is perhaps Plusnet are blocking a certain type of mobile IP address?
Any help would be great
Cheers
9 REPLIES 9
Fixes: 585
Re: VPN
What type of VPN ?
I would guess its a CGNAT issue https://forums.thinkbroadband.com/mobilebroadband/4690151-cant-connect-with-idmobile-but-can-with-th... .
I've had problems connecting to the office VPN from some mobile networks.
ChrisD2
Re: VPN
PPTP
Fixes: 585
Re: VPN
Yup, that will be a CGNAT issue.
Do you have any other VPN options ?
Fixes: 480
Re: VPN
Moderators Note
This topic has been moved from Broadband to Tech Help
ChrisD2
Re: VPN
No, I've always used this. It's the DD wrt VPN router type set up. Used it for years, never had any issues connecting to it.
Fixes: 585
Re: VPN
PPTP will struggle with a CGNAT setup which some ( but not all ) mobile providers use, since it requires the GRE protocol to be forwarded.
DD-WRT does seem to support OpenVPN https://wiki.dd-wrt.com/wiki/index.php/OpenVPN , that SHOULDNT have the same issues with CGNAT as it uses SSL.
ChrisD2
Re: VPN
It's was a bit beyond me setting up the openvpn thing, plus I had the PPTP working fine so didn't really need to.
You think there is any other way do you think? Is there a way to change the mobile IP or someone mad like that?
Fixes: 585
Re: VPN
If its a CGNAT  issue then there's nothing you can do about it.
ChrisD2
Re: VPN
Thanks for the information. It's all very helpfull. I might try the other VPN set up and see what I get from that.
