Problem with win 10 update
FIXED- Subscribe to RSS Feed
- Problem with win 10 update
20-05-2017 11:09 AM
I let one of my PC update windows automatically, it updated last night, this morning some of my software does not work (SAGE), so I restored to the previous restore point, this seemed to run OK, the PC reboots and now I get 'missing operating system'.
Going into the BIOS reveals the hard disk is present and recognized (it is a 25GB SSD disc).
I'm guessing as part of the upgrade the disc failed.
Replacing the hard disk is easy enough but how do I install the WIN 10 OS without a product key
Fixed! Go to the fix.
Re: Problem with win 10 update
20-05-2017 11:38 AM - edited 20-05-2017 11:38 AM
You don't need a key it should install via your hardware setup it remembered
20-05-2017 11:39 AM
I love how it remembers your mobo
20-05-2017 11:42 AM
Have a look here.
20-05-2017 11:46 AM
20-05-2017 12:00 PM
27-05-2017 6:41 AM
thank guys, new disk purchased, installed and working
@St3 love how it remembers your mobo - was surprised
27-05-2017 5:23 PM
It's well worthwhile having a peep at your disks SMART data every few months.
29-05-2017 6:30 AM
@VileReynard How is the best way to do that?
On a different note Crashed SSD disks change hands on ebay for > £20 anyone know why?
05-06-2017 1:50 PM
With technical know-how (ie knowing how to use Google properly) many of the "failed" SSDs can be easily fixed = worth something.
05-06-2017 1:56 PM
It's all very well being able to use a search engine but that doesn't mean you'll be able to understand the content of the results it produces.
