Problem with win 10 update
I let one of my PC update windows automatically, it updated last night, this morning some of my software does not work (SAGE), so I restored to the previous restore point, this seemed to run OK, the PC reboots and now I get 'missing operating system'.
Going into the BIOS reveals the hard disk is present and recognized (it is a 25GB SSD disc).
I'm guessing as part of the upgrade the disc failed.
Replacing the hard disk is easy enough but how do I install the WIN 10 OS  without a product key
10 REPLIES 10
rongtw
Fixes: 12
Re: Problem with win 10 update
You should be able to download Windows media creation tool to a USB
You don't need a key it should install via your hardware setup it remembered
St3
Aspiring Champion
Fixes: 5
I love how it remembers your mobo Wink
Browni
Aspiring Hero
Fixes: 49
Have a look here.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
rongtw
Fixes: 12
Ste its Magic 💐
Browni
Aspiring Hero
Fixes: 49
I can confirm 1st hand that the activation troubleshooter works as I am on my 4th motherboard since originally installing Windows 10 Grin
thank guys, new disk purchased, installed and working
@St3 love how it remembers your mobo Wink  - was surprised
VileReynard
Champion
Fixes: 17
It's well worthwhile having a peep at your disks SMART data every few months.
@VileReynard How is the best way to do that?
On a different note Crashed SSD disks change hands on ebay for > £20 anyone know why?
paul_blitz
With technical know-how (ie knowing how to use Google properly) many of the "failed" SSDs can be easily fixed = worth something.
Fixes: 43
It's all very well being able to use a search engine but that doesn't mean you'll be able to understand the content of the results it produces.
