Port Forwaridng
ross_37
Port Forwaridng
Hi i have identified that port FORWARDING   is not working on my plusnet two router
I have checked that dynamic forwarding is working and actuall remove this but same thing no change
I have check the log
Time and date Message
19:29:28, 09 Jan.
admin login success from 192.168.11.11
19:29:19, 09 Jan.
admin timeout from 192.168.11.11
19:28:56, 09 Jan.
DDNS Status: no change (the hostname portugal11.mynetgear.com has a successful update but the IP address or other settings have not changed)
19:28:55, 09 Jan.
DDNS Status: connecting
19:28:55, 09 Jan.
DDNS Service name NoIP, Wan ip 80.229.162.159
19:25:21, 09 Jan.
ARP [del] br0 192.168.11.72 02:0f:b5:45:7d:8e
19:24:47, 09 Jan.
LAN [ADD] ARP 192.168.11.71 with 02:0f:b5:45:7d:8e from br0(wl0)
19:24:47, 09 Jan.
ARP [add] br0(wl0) 192.168.11.71 02:0f:b5:45:7d:8e
19:24:41, 09 Jan.
DHCP device Connected: 192.168.11.71, b2:4c:13:45:7d:8e, iPhone
19:24:41, 09 Jan.
DHCP lease issued 192.168.11.71 to b2:4c:13:45:7d:8e iPhone, lease duration is 86400 seconds
19:24:41, 09 Jan.
5G Client associate from b2:4c:13:45:7d:8e (IP=192.168.11.71) RSSI=0, Rate=0Mbps, host iPhone
19:24:39, 09 Jan.
LAN [ADD] ARP 192.168.11.71 with b2:4c:13:45:7d:8e from br0(wl0)
19:24:39, 09 Jan.
Receive a DHCP request
19:24:34, 09 Jan.
19:24:14, 09 Jan.
DHCP device Disconnected: 192
Any input welcome to progress
Any ideas as to where to look or check
6 REPLIES 6
Re: Port Forwaridng
@ross_37 welcome to the community.
I note you have a static IP Address, Port Forward rule is set for inbound connections.
The log file example does not show any port forward activity.
In the members centre there is a 'Account' based Firewall, you need to check this is set to 'Low' or 'Off'
From the members centre Home page navigate ->Broadband -->Broadband Firewall (you need to scroll down the page)
Maybe so more detail on what you are attempting would be helpful as well.
Edit: added members centre link
ross_37
Re: Port Forwaridng
Many thanks i change the advanced setting from high to  allow http &https through and going to test
When testing it looks to be working
2:41:40, 10 Jan.
FWL Port Forward Server(192.168.11.180) TCP 8001 accepted a new connection from 155.133.20.129
12:41:34, 10 Jan.
12:41:26, 10 Jan.
12:41:22, 10 Jan.
12:41:20, 10 Jan.
12:41:19, 10 Jan.
12:39:21, 10 Jan.
ARP [add] br0(eth2) 192.168.11.72 b2:4c:13:45:7d:8e
12:38:59, 10 Jan.
ARP [add] br0(wl0) 192.168.11.78 02:0f:b5:c6:ad:72
12:38:58, 10 Jan.
ARP [del] br0 192.168.11.78 02:0f:b5:c6:ad:72
12:38:22, 10 Jan.
ARP [add] br0(wl0) 192.168.11.23 02:0f:b5:76:ad:e8
12:38:22, 10 Jan.
ARP [del] br0 192.168.11.23 02:0f:b5:76:ad:e8
12:37:21, 10 Jan.
ARP [add] br0(wl0) 192.168.11.209 02:0f:b5:76:6c:2f
12:37:21, 10 Jan.
ARP [del] br0 192.168.11.209 02:0f:b5:76:6c:2f
however the tv channel is not getting through. I need to investigate further as it working locally  on the home lan
ross_37
Re: Port Forwaridng
Yes things looked good but when l tested  i am still not able to get through the router the port forwarding seems to work but not allowing to connect to the device
It works  on the home lan but not when l use public IP address. I Have configured the port forwarding to  7777 it doesn't which i had previously used sucesfully
Any direction would be appreciated
Re: Port Forwaridng
When you say you can see the port forward rule working you see a log message something like this when you attempt to connect remotely.
hh:mm:ss, dd mmm. FWL Port Forward Server(192.168.x.xxx) TCP 7777 accepted a new connection from <external IP Add>
Which application are you setting up, has this worked before on the Hub Two?
With the account based firewall have your tried setting to Low or Off? Don't forget to reboot the Hub.
ross_37
Re: Port Forwaridng
Hi and thanks for your help
I think yesterday really resolved my issue on the port forwading however i am still having issues.  ( yes l realised that l needed to restart the router)
I am using VLC  to connect from my sat box to my iphone,  but at this point i am  still trying to connect ti my desktop  /laptop ,
I should indicate that this has been like this for some time and thought it was the router. I now sure the the forwarding is working.  all  be it intermittently and investigating
Thanks for your assistance
Re: Port Forwaridng
@ross_37
So to clarify, you are trying to connect to a sat box using your iPhone when you are away from home with the VLC app?
