Plusnet Hub One
avatastic
Re: Plusnet Hub One
Quote from: Chris
Quote from: chenks76
for existing customers it's not launching though.
Yet....
It will be after the new provisioning and billing systems are in place.
F9 member since 1999
F9 ADSL customer since 2004
F9 FTTP customer since 2024
bobpullen
Fixes: 331
Re: Plusnet Hub One
Quote from: spoon
Quote from: Bob
Quote from: w23
Shape and accessories seem to match but then, would it be a 5A or 5B (or random mix of both)?
A (subject to change of course).
Could you confirm that this is G.INP compatible please.
It's been a while since I looked at the G.INP stuff, but the Hub One behaves the same way as a model A BT Home Hub v5 in this respect (compatible on the downstream but not on the upstream?).
Using a Hub One, my line is in sync at 19999 / 79906 with a maximum attainable downstream of 88875kbps.
w23
Fixes: 4
Re: Plusnet Hub One
Quote from: Bob
Would you know whether your cabinet is ECI or Huawei?
Call me 'w23'
maranello
Re: Plusnet Hub One
I see the Plus One has a USB port. Is this configurable for a usb printer connection and/or an external usb hard drive?
My other car isn't a Ferrari
bobpullen
Fixes: 331
Re: Plusnet Hub One
Quote from: w23
Quote from: Bob
Huawei and my line has had retransmission applied before when I've been using Broadcom kit.
Quote from: maranello
External storage yes. USB printer no (at least it's not something that's supported).
Oldjim
Resting Legend
Fixes: 63
Re: Plusnet Hub One
So I assume that the following are not supported
TBB BQM
Any monitoring software which relies on telnet
This means that self help via these forums will be strictly limited as it is with the 2705
Another question - why aren't you providing the type B - is this because you are using BT old stock
What are the advantages - if any - of the Lantiq chipset over the Broadcom
bobpullen
Fixes: 331
Re: Plusnet Hub One
Quote from: Oldjim
TBB BQM
The device won't respond to ICMP echo requests. I'm currently working around this by sticking a device in the DMZ and having that do the job instead.
Quote from: Oldjim
Telnet is disabled.
Quote from: Oldjim
I wasn't party to the decision, but we're not using old stock. AIUI BT have been known to alternate between stock variants in the past anyway. On a personal note, when I used a type B earlier in the year, I had problems with certain aspects of the port forwarding that I never managed to fix.
Quote from: Oldjim
I suspect they both have their merits depending on the circumstances. There's a lot of variables involved with each individual broadband circuit.
goldenfibre
Seasoned Pro
Fixes: 12
Re: Plusnet Hub One
Hub One is rubbish anyway! I wouldn't buy it off plusnet. I use my own router!
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
how do you know? you haven't got one.
also, double negative... you wouldn't not buy one? so you would buy one then.
dick:quote
goldenfibre
Seasoned Pro
Fixes: 12
Re: Plusnet Hub One
Cos it the same as BT Home Hub 5 (I used to have it before and I hate it)
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
yet you just said you would buy one.
anyway, as you've not had a hub one, you can't state whether it's any good or not.
edit - nice stealth edit  Grin
w23
Fixes: 4
Re: Plusnet Hub One
Quote from: Oldjim
Not telnet based but there is basic monitoring software available: http://www.vwlowen.co.uk/RouterStatsHub/routerstatshub.htm
Call me 'w23'
Andrue
Re: Plusnet Hub One
Quote from: tonyappuk
It seems to make sense to wait if you have a reasonable download speed on ADSL2+ (mine's about 10Mhz) until all customers are offered a single box self install upgrade.
Or you could just buy your own combined modem/router and when you order fibre and tell PN not to bother shipping the free one. You don't need to use a router supplied by PN. They don't require us to and any router can be configured to work with PN's service.
Oldjim
Resting Legend
Fixes: 63
Re: Plusnet Hub One
except - and this is the point I believe - you have to have an engineer visit
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
only if you're an existing customer upgrading.
new customers will be self install.
