Plusnet Hub One
bobpullen
Fixes: 330
Re: Plusnet Hub One
Quote from: w23
Shape and accessories seem to match but then, would it be a 5A or 5B (or random mix of both)?
A (subject to change of course).
ITWorks
Fixes: 9
Re: Plusnet Hub One
Quote from: Chris
Sorry that you're not happy but that's the decision that's been made. I'm hopeful that it won't be too long before existing customers get this too.
Seems like existing customers are seen as second class on this ( getting rid of old stock), already paying PN money,  and then most likely need to take time off work if they want to upgrade to fibre,  but no such issue for new customers.
Regards
Mike
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
That's not the reason at all, the Hub Zero will continue to be supplied on ADSL connections.
ITWorks
Fixes: 9
Re: Plusnet Hub One
Okay,  getting  rid of old stock which has the fibre firmware?,  So what is the reason?, do you think it is fair exsiting paying customers will most likely have to take time off work and new ones won't?
Regards
Mike
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
It's a business decision based on a number of factors, that I'm not going to discuss. I appreciate that you're not happy that this hasn't been launched for existing customers too, but surely launching it at all is a good thing?
pwatson
Re: Plusnet Hub One
BT won't be supplying the VDSL modem from January next year, so existing customers upgrading to fibre will need the new router at this point anyway.
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
Quote from: pwatson
Quote from: Chris
Wink
anniesboy
Re: Plusnet Hub One
Can existing fibre customers get this modem router,if they start a new contract?
I ask as I will shortly be redecorating and getting rid of one box would be good
ITWorks
Fixes: 9
Re: Plusnet Hub One
Yes of course, better late than never  the decision to not offer to exsiting customers as well,  says to me that new are more important than exsiting. I am sure other existing upgrading customers would feel the same.
Regards
Mike
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
Quote from: Chris
for existing customers it's not launching though.
so what you provide to a different set of customers is irrelevant to me.
all i can see is that, as an existing customer, i get a different service.
a service, that most likely could resist in an engineer not turning up at all resulting in a wasted day.
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
At the moment no. Further down the line possibly, however I can't give any timescales or costs at this point.
Chris
Legend
Fixes: 169
Re: Plusnet Hub One
Quote from: chenks76
Yet....
jelv
Fixes: 10
Re: Plusnet Hub One
Quote from: Bob
Quote from: w23
Could you confirm that this is G.INP compatible please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
tonyappuk
Re: Plusnet Hub One
It seems to make sense to wait if you have a reasonable download speed on ADSL2+ (mine's about 10Mhz) until all customers are offered a single box self install upgrade. I don't want two boxes or have to wait in for a man who might not come! For the time being Plusnet will have to forego getting another £10 a month from me.
Tony
chenks76
All Star
Fixes: 12
Re: Plusnet Hub One
10Mhz? seems like a poor connection you have  Kiss
