Plusnet, Grandstream HT802 and A&A VOIP
Fixes: 585
Re: Plusnet, Grandstream HT802 and A&A VOIP
@TimF2 that looks good to me. Can I check that you have the ht802 connected to one of the lan ports 1 - 3 (not the red wan port 4 )  on the Hub 2 ?
TimF2
@MisterW
Thanks for that, yep connected to LAN 1
I've also just tried to use Zoiper softphone on my iPad and that also won't register - comes back with a 403 Forbidden message 😬
Fixes: 585
In that case , double check the I'd and password. Try regenerate a new password.
I regularly use zoiper on a Smart phone both to my office pbx and to my home voip account
Fixes: 480
Moderators Note
This topic has been moved from Everything Else to Tech Help
