Deco M5
Robpg1970
Deco M5
I purchased a Deco M5 as I was having problems with internet dropping in bedrooms. I turned the router off, plugged first one in. Went through steps in app. Had to ask plusnet for some technical data but they wouldn’t tell me (even though dat before someone else said I was allowed to set up mesh system and to call support if needed help). It all seems to be working fine  everything is connecting to the new network no dropping out when surfing etc. However I can still see the plusnet connection in my list of WiFi connections. Is this correct? I’ve seen some threads where people have switched WiFi off on router but it didn’t ask me to do that on tplink app. I ain’t technically minded so simple explanation would be appreciate 😁
15 REPLIES 15
Fixes: 1,495
Re: Deco M5
It’s not clear from this whether you plugged the m5s into the PM router or not?
You’ll need to as the m5 doesn’t have a modem built in.
Also you’ll need to switch the Wi-Fi off on the router yourself the tp link software won’t do that for you.
You can access the router at http://192.168.1.254
Robpg1970
Re: Deco M5
I turned router off plugged m5 into back and turned back on. so I just now need to click on that link and disconnect internet?
Fixes: 1,495
Re: Deco M5
You need to turn off the wifi, not disconnect the internet.
Navigate in a web browser to 192.168.1.254.
Click Advanced Settings
Enter your Hub admin password when prompted (unless you've changed it, you'll find the default password on the settings card)
Continue to Advanced Settings.
Click on Wireless.
Think there's a turn off wireless there
Robpg1970
Re: Deco M5
Thanks for your help. Seems to be working. Will taste the original blackspot over next few days and hopefully everything sorted
Fixes: 1,495
Re: Deco M5
Glad it’s working Smiley
Bold_guy51
Re: Deco M5
Good afternoon all 👍. I have just come back to Plusnet ffb I have the TP link Deco M5 and would also like a bit of technical help if possible. Would I put the router into modem mode and that's it plug the mesh system in and WiFi all over the house is it this simple.
Thank you
Fixes: 585
Re: Deco M5
If youre on FTTP (full fibre) then, forget about the PN router,  just connect the Deco M5 directly to the ONT , configure the WAN connection for PPPoE with your Plusnet username & password
Bold_guy51
Re: Deco M5
The TP link isn't the router but the mesh system I would need router with WAN port for the ONT I believe
Fixes: 585
Re: Deco M5
The Deco can operate I router or access point mode. I assumed that with you asking about modem mode on the pn hub then you were using router mode on the Deco.
If you're using access point mode, then just connect it to a lan port, ( the ONT is connected to port 4 ) ) on the pn hub, leaving that in its normal mode.
BTW modem mode on the PN hub doesnt make sense ( in fact it won't work) for fttp , the ONT is the modem.
Bold_guy51
Re: Deco M5
So in reality I don't need a modem is this correct if this is correct I am looking at a couple of TP link routers with WiFi 6
Fixes: 585
Re: Deco M5
correct
If the deco m5 is working ok for you at the moment, then just carry on with that.
Bold_guy51
Re: Deco M5
Will be connected upto pn on wed/Thurs I did originally try with my old supplier and didn't connect I do have or supposed fttp
Bold_guy51
Re: Deco M5
PN hub2 arrived yesterday I was thinking of buying my own router/modem was looking at again a tp link. This is the email I received back from TP link
Hello Andrew,
Thank you for contacting TP-Link support.
For your issue, currently, Deco supports five internet connection types: PPPoE, Static IP, Dynamic IP, PPTP, and L2TP. That means Deco can work with most internet service providers.
Thanks for your cooperation and patience.
I don't know what the heck this means can someone advise please.
Thank you
Fixes: 585
Re: Deco M5
@Bold_guy51
 I did, earlier.
