Plusnet, Grandstream HT802 and A&A VOIP
TimF2
I wonder if anyone can help me please?
I have an active A&A voip account with registered number, a Grandstream HT802, Plusnet Fibre and some Panasonic Kx-tg8321e.
Having tried for 5/6 hours now it is proving a problem to get them all to play nicely!
I have followed the guide here: https://support.aa.net.uk/VoIP_Phones_-_Grandstream_HT8xx but am stil running into problems.
At first I was unable to register the HT802 in the A&A GUI - it just said no registered devices and the Grandstream GUI STATUS page confirmed the same on the FX port.
I had some limited success by applying a STUN in Grandstream GUI. It then showed the HT802 in the A&A account as registered and also in the Grandstream STATUS page.
This was also confirmed by the blue lights (x3) lit on the HT802. However, if I try and make or receive a call I get no ring tone and it just cuts off.
Any further altering of settings in the Grandstream GUI causes the FX port to become unregistered and the blue FX light goes OFF.
I have checked on the Plusnet router and SIP ALG is disabled.
Would really appreciate some help if anyone is able!
Tia
18 REPLIES 18
Fixes: 583
Re: Plusnet, Grandstream HT802 and A&A VOIP
Tryy setting the 'prefer primary sip server...' to No
Fixes: 479
@TimF2  Welcome to the Community Forums.
Based on my HT812 settings have you. in the Profile Settings changed the following from the default USA to UK settings:
TimF2
Thanks for your quick reply Mister W, just checked and it's set to No.
TimF2
Thanks Baldric.
Yes, I did that.
Fixes: 479
@TimF2
Enable Logging in Advanced Settings:
Then see if there are any clues in the SIP File, see tab at bottom of the Status page.
TimF2
Thanks Baldrick.
Looking at the SIP log it is showing a couple of failures when RECEIVING from A&A.
It throws up:
SIP/2.0 401 Unauthorised
SIP/2.0 403 Forbidden
Any ideas?
Fixes: 479
@TimF2
Unless @MisterW has any ideas I would try contacting A&A. I have found them very helpful. My HT612 works without using a Stun server though I have now added  stun.aa.net.uk as belt and braces. It also works through the Plusnet account firewall, which is set to High.
Fixes: 583
@TimF2 sounds like an authentication issue to me
unless you've got the Incoming call configured to send to my server in the a & a control panel. It should only be send to registered phone.
Does the ht802 show as registered on a & a ?
As @Baldrick1 says, stun shouldn't be needed
TimF2
Thanks @Baldrick1.
Out of interest where in your Plusnet account do you set the firewall? I can't find that option in my account.
If I login into the router though I have options for the firewall of Default, Block all or Disable?
Just one other thought, I guess you have FTTP not FTTC?
TimF2
Thanks @MisterW
I had brief success this morning registering it. It showed in the A&A control panel but that then stopped working and disappeared.
So I then reset the HT802 to start from scratch (following your suggestions) but have been unable to get it registered again since.
I've not configured it to send to my server - I've only tried to send to registered 'phone.
Fixes: 583
Out of interest where in your Plusnet account do you set the firewall? I can't find it in my account.
If I login to the router I have options for the firewall of Default, Block all or Disable?
Its not the router firewall , its in your account.
Login to the member centre and go to https://www.plus.net/member-centre/broadband/firewall
Should be set to Off , if it needs changing you will need to drop and reconnect the connection ( restart the router )
Fixes: 583
In that case you've got an error in the configuration , probably in the username or password
Fixes: 479
@TimF2
 I am on FTTC using a Hub 2. If you have a Plusnet firewall it is in your account settings, I believe that it’s only there on old accounts. Either way it’s irrelevant as there are no problems even when set to high. My hub firewall is on the default setting.
Are you using the correct password from your A&A account? It’s not the account password itself but the send/receive one.
In your GS User settings the password should self populate from the Profile page and the other three fields all use your SIP phone number in international (+44) format.
TimF2
@Baldrick1
I think I'm using the correct username and password!
SIP user ID & Authenticate ID is the 'phone number with +44 and no leading zero. e.g +44123456789
The password I am using is the one generated on the control pages. I've attached a screenshot.Firefox_Screenshot_2023-04-16T18-54-02.474Z.png
