Outlook - Windows 11 - Email Preview - Attachment - PDF
lachlan79
Good morning
When I open an email with a Word attachment. In the preview screen, I try to print the word file, but it sends it straight to PDF and fails. Yet when I open Word in Desktop it prints fine to printer. How do I stop Print Preview automatically goes to PDF mode in Outlook?
Regards
Andrew
8 REPLIES 8
Fixes: 480
Re: Outlook - Windows 11 - Email Preview - Attachment - PDF
Moderator's note:
Thread moved from Email to Tech Help
Champnet
Fixes: 21
@lachlan79  Check default printer in Outlook, (File Print Printer) it may be different to Word default printer.
lachlan79
Yes default printer is Printer. This only happens in Email preview mode. Once I open document fully, and print, it prints fine.
Champnet
Fixes: 21
Having trouble replicating the problem, which versions of outlook & word ?
lachlan79
Thanks for your reply.
I checked in with Microsoft and they couldn't solve the problem either.
Windows 11. When I try to print from a preview of Word document in Outlook. Rather than print it, it tries to print it as a PDF and then fails.
However, in desktop word, file prints fine to my printer, and my printer is set as default. Its just an issue in email preview section.
@lachlan79
What make and model printer are you using? Sometimes the answer is with the associated app that comes with the printer.
Having it (the printer) 'set as default' might the wrong setting.
Champnet
Fixes: 21
lachlan79
This is exactly the issue, oh well
Moderator's note:    Fix allocation corrected
