Xbox Advert - Windows 11 Login Screen
lachlan79
Good morning,
New computer - windows 11.
When I login with my PIN, I sometimes click in the centre of screen on the XBOX advert. When I login I end up with an XBOX page. Is there a way to remove the XBOX advert from PIN screen?
Regards
Andrew
3 REPLIES 3
markhawkin
Champion
Fixes: 22
Re: Xbox Advert - Windows 11 Login Screen
Have a read of this, I think it will let you do what you want.
https://www.elevenforum.com/t/removing-xbox-ad-and-random-picture-on-boot-up.19067/
Funnily enough, I got the annoying X Box ad on startup today.
Your question may have helped me banish it as well.
Fixes: 480
Moderator's note:
Thread moved from Email to Tech Help
lachlan79
It looks like its tied into Windows Spotlight. If you select Spotlight on Lock screen, it comes up. If you don't, when you don't see the Xbox advert. But I like Windows Spotlight. Didn't find a better solution so far.
