OpenWRT BT PlusNet Hub VDSL2 Gigabit WiFi/Wireless AC OpenVPN VPN router 19.07.5
- Re: OpenWRT BT PlusNet Hub VDSL2 Gigabit WiFi/Wire...
3 weeks ago
just seen this on Ebay whilst looking at something i purchased
I have absolutely no affiliation with who ever this seller/persons are , merely curious because i looked at WRT a couple of weeks ago and it appeared there was Zero chance of it happening.
Anyway there is an advert for a seller refurbished PlusNet Hub One with WRT, the seller notes suggest they do know what they are doing. the above is the advert heading, not a link,
i have not looked into this YET.....can a BT Smarthub 6 be customised? with WRT I bought a BT Smart Hub 6 it is ( so far superior ) to the Plusnet router imo.
Empire
Re: OpenWRT BT PlusNet Hub VDSL2 Gigabit WiFi/Wireless AC OpenVPN VPN router 19.07.5
3 weeks ago - last edited 3 weeks ago
There is no support for OpenWrt on newer Smart Hubs.
Regarding Openwrt on HH5A/Hub One, see original installation guide which most ebay sellers won't disclose to its existence in their listings:
https://openwrt.ebilan.co.uk/viewtopic.php?f=7&t=266
Most issues with openwrt on HH5a are down to poor throughput and wifi performance. Use an external wireless access point running stock firmware for best wireless performance.
3 weeks ago
My BT Smart Hub 6 on PlusNet works fine stock, but i would like is to be able to changes DNS servers,
3 weeks ago
I understand the BT Business Smart Hub 6 permits owners to change DNS server settings.
