My website can't be accessed
llwsc
My website www.lochlomondwaterskiclub.co.uk can't be accessed by any browser I use, I can access the site through my FTTP program but can't view or download any folders, is this a Plus.Net server problem?
9 REPLIES 9
plusnettony
Fixes: 80
Re: My website can't be accessed
Sorry about this, it's been raised.
 Tony T
llwsc
Update, I can't connect to my website now by FTP and in a browser the website cannot be found now although searches show it
plusnettony
Fixes: 80
This is being fixed as I type.
 Tony T
llwsc
Thanks! Everything is back up and running can you tell me what the problem was?
plusnettony
Fixes: 80
A bug in the migration process I believe.
 Tony T
llwsc
Thanks, I just noticed my Nominet registration expires on 5/11 will this be updated? I know it has been missed a couple of times
plusnettony
Fixes: 80
That's something you'll need to ask Greenby. As you've migrated, you'll renew via them. I am not sure when/how notification about this will go out. I'll mention to them for you.
 Tony T
llwsc
That would be good if you could contact them or give me a way to contact them myself, thanks!
plusnettony
Fixes: 80
The only way to contact them directly is to use the web site help section or raise a ticket.
 Tony T
