tp link extender
FIXED- Subscribe to RSS Feed
- tp link extender
Thursday
I have a ‘tp link’ Wi-Fi extender at the bedroom end of my bungalow. It works with my Plusnet router but, in my wi-fi settings, it shows separately to my router. It has the same name, but with ‘_Ext’ at the end.
They don’t automatically mesh together. I have to manually swap between them, in my settings, to get the best signal.
How can I mesh them together, so that they give a strong signal throughout the bungalow, without having to choose the best signal manually?
Thanks,
David
Fixed! Go to the fix.
Thursday
Have you tried configuring the TP Link extender to offer the same SSID / Password as your Plusnet router ?
Re: tp link extender
Thursday
Hiya Philip,
It’s worked!
Thank you, very much.
Best wishes,
David
