Mobile Broadband
APB
Mobile Broadband
How good is it? Can you watch TV iplayer ?
Would be grateful for any advice or observations before I sign up for it.
4 REPLIES 4
Fixes: 480
Re: Mobile Broadband
Moderator's note:
Thread moved from Broadband to Tech Help
mystreet1
Seasoned Pro
Fixes: 7
Depends on your signal. MIL was using '3' in one of their provided routers. Was getting s download of 38Mb, but the signal strength was 5 bars (lights).
Order on line and you have 14 days to test.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
markhawkin
Champion
Fixes: 22
How good is it?
Variable and often less good than broadband using a phone line. Definitely less good than full fibre in my view
Streaming is generally possible (it depends on which network is best for reception and data throughput in your area as to how good it looks)
I would get a cheap sim on the network you propose using and put it in a spare phone or the WiFi unit you intend using and try it for a few days.
I suspect you will find it doesn't compare well to broadband using a filxed wire or fibre.
If you are very near a phone mast in an area of low population it can work extremely well, otherwise less so.
Protech
Seasoned Pro
Fixes: 8
It all depends on the mobile signal and location, and careful positioning of the router.
I've had both good and bad experiences with mobile broadband . Purely down to location.
Most recently I set up a temporary mobile broadband for my daughter in a 3rd floor flat in an urban city location.
On an unlimited data EE SIM she's been getting 100mbs reliability (speed limited by SIM) . Only one outage for a few hours over the last year.
You can check out but you can never leave ( easily)
