Mint 18 released
- Mint 18 released
Mint 18 released
03-07-2016 5:12 PM
Actually released on Thursday
Mate & Cinnamon versions at the mo.
Upgrades from 17.x will be explained later.
Running it now on my main PC. (Booted this morning with an error about /dev/null, so took the opportunity to upgrade with a clean install)
Re: Mint 18 released
04-07-2016 2:55 PM - edited 04-07-2016 2:57 PM
HairyMcbiker wrote:Actually released on Thursday
Indeed. I downloaded and have been running the Cinnamon version since last week.
06-07-2016 3:00 PM
So..... new version of Mint.... great.!.. but...
What is the difference between the "old" Mint 17 and the "new" Mint 18 ?
are the changes worth worrying about, or are they "updates" to the inside workings, more than the "outside" operational usages.... ?
![](/skins/images/C31306F9CADE65DF69D0EAD1C7966909/responsive_peak/images/icon_anonymous_message.png)
06-07-2016 3:07 PM
06-07-2016 6:05 PM
Mint 18.1 will be released next year, but it is not a massive change, just some better apps. No need to upgrade unless you want to.
06-07-2016 11:44 PM
07-07-2016 11:29 AM
I don't actually know.
The etc/init.d folder is still there.
How do you know?
07-07-2016 11:42 AM - edited 07-07-2016 12:01 PM
As I understand it's use is optional, Mint currently uses Upstart and SysV init but you can use systemd if needed.
Note to self, only cite current articles not outdated ones.
07-07-2016 11:49 AM
But it looks like 18 used systemd
hairybiker@octo:~$ ps ax|grep systemd
416 ? Ss 0:00 /lib/systemd/systemd-journald
452 ? Ss 0:00 /lib/systemd/systemd-udevd
879 ? Ss 0:00 /sbin/cgmanager -m name=systemd
881 ? Ss 0:00 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation
905 ? Ss 0:00 /lib/systemd/systemd-logind
1810 ? Ss 0:00 /lib/systemd/systemd --user
6886 pts/0 S+ 0:00 grep --color=auto systemd
07-07-2016 12:02 PM - edited 07-07-2016 12:14 PM
I'm running LMDE (Mint based on Debian) and I appear to have hundreds of systemd files - which I am totally clueless about. I also have init.d which appears to be still working (including a few changes I made).
I suspect that this is because systemd --version prints
systemd 215
+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR
So that systemd runs SYSVINIT - but I'm guessing there...
BTW ps ax | grep systemd
2050 ? S 0:00 /sbin/cgmanager --daemon -m name=systemd
3274 ? S 0:00 /lib/systemd/systemd-logind
So I've got an extra couple of systemd processes.
07-07-2016 12:06 PM
As long as I can still add an init.d script and it works it will do for now for me. Unitl I get to know systemd better.
07-07-2016 12:29 PM
In the description for the systemd package (which I have loaded) it says:-
systemd is a replacement for sysvinit. It is dependency-based and
able to read the LSB init script headers in addition to parsing rcN.d
links as hints.It also provides process supervision using cgroups and the ability to
not only depend on other init script being started, but also
availability of a given mount point or dbus service.Installing the systemd package will not switch your init system unless you
boot with init=/bin/systemd or install systemd-sysv in addition.
08-07-2016 1:59 PM
Yeah Debian moved to systemd by default in Jessie (8.0) so I guess it makes a lot of sense for Ubuntu/Mint and other distros derived from Debian to go the same way.
08-07-2016 5:43 PM
Even though no-one (almost) understands systemd and how to operate it?
08-07-2016 6:44 PM
I've had systemd since Fedora switched to using it some time ago. No-one was born with the knowledge of how to operate it, but I'm sure most people will be able to figure it out.
