MS Office XP
petlew
MS Office XP
I have some parts of MS Office XP installed and, was wishing to add another option (Outlook, to use with my PDA) however, I have found that the product key (hand written on the disk) is being rejected. is there anywhere in the other already installed parts (Word, Excel and PowerPoint) that will show me the product key I used to install those. It doesn't show in help/about, the product I/d shown there is quite different. I suspect the key "might" show in the opening splash window as Word/Excel/PP open, but it's not there long enough to get a good look.
In the end, I found I could install Outlook through "add remove programmes" (or whatever it is in Vista!!) without the product key, but I'd still like to get a look at the key for future reference, if possible. Or is it possible to "pause" the opening splash window?
4 REPLIES 4
Oldjim
Resting Legend
Fixes: 63
Re: MS Office XP
petlew
Re: MS Office XP
Thank you Jim, it worked very well. However, it seems the key I have is correct.
minkey
Re: MS Office XP
petlew
Re: MS Office XP
Yes, thank you.
