Issues connecting to wifi ?
- Issues connecting to wifi ?
04-04-2017 12:37 AM
Re: Issues connecting to wifi ?
04-04-2017 2:07 AM - edited 04-04-2017 2:09 AM
What is the router model number (eg. Hub One, Hub Zero/2704n) ?
Do other wireless devices connect to internet OK ?
04-04-2017 5:15 AM
hi it's a plus net one router - and i can attach my laptop ok i've tried resetting the hub - resetting the wifi connection on my iphone 6s but nothing changes
04-04-2017 7:27 AM
@sandyk57 wrote:
when i click on plusnet and try to go on my broadband it takes me to the router hub management page and asks me to log in - it says my phone is connected but its not is there anyone out there that can offer some advice please and thanks
I don't know what you mean by 'when i click on Plusnet'. But if you get to the router hub management page then you must indeed have a wifi connection. And once you have the wifi connection there is no need to do anything else, just go ahead and surf. Open Safari and go.
04-04-2017 9:21 AM - edited 04-04-2017 9:25 AM
If you still cannot use Safari to navigate to external websites as advised by ReedRichards, see if the follwoing helps, because there are known issues when using IOS devices with the Hub One.
You may need to separate (un-sync) the 2.4 and 5 GHz wifi bands.
Use a web browser and go to 192.168.1.254 to bring up the web admin page. Log into the hub.
Navigate to the page shown below and make two changes shown below and save the settings.
(eg. Just append '-5GHz' or something similar to the 'Wireless SSID')
04-04-2017 12:04 PM
@bill888 wrote:
...there are known issues when using IOS devices with the Hub One.
Known issues that would allow access to the router management interface but not to the Internet?
04-04-2017 1:04 PM
04-04-2017 1:18 PM
bill888 where you have highlighted 5GHz it just says the name of my router Plusnet-JNJM nothing else do you want me to put somthing after this (sorry not very tech savvy just know the basics) thanks
04-04-2017 1:48 PM - edited 04-04-2017 1:50 PM
yes.
btw, are we still led to believe you still can't use safari to access websites if you ignore the Hub login page?
04-04-2017 2:37 PM
04-04-2017 3:46 PM
04-04-2017 3:51 PM - edited 04-04-2017 4:17 PM
Correction:
Looks like you are being shown the hub login page (showing incorrect Broadband username, [email protected]), and then being prompted to choose a wifi network to enter the password, or is it the other way around?
What happens when you choose one of the Plusnet-JNJM wifi networks and enter the wifi password ?
On your laptop, can you go to the hub admin page at 192.168.1.254 and navigate to this page and double check your Plusnet account username and password are displayed. Adv.Settings-Broadband-Internet.jpg
04-04-2017 5:20 PM
04-04-2017 5:30 PM
You did not answer the question; what do you see on your laptop? Superficially it looks as if your Hub is in a pre-operational state trying to reset itself. I am surprised you can get an internet connection on any device under those circumstances.
04-04-2017 5:32 PM - edited 04-04-2017 5:33 PM
Go to the above mentioned hub admin page and manually type in your plusnet account username & password. Press the button at bottom of the page to save the settings. It is the same username and password you use to log into the Plusnet website to access your account for billing etc.
Make sure the username ends in '@plusdsl.net'.
You may need to restart the hub after saving the settings.
If the username and password are entered incorrectly, the laptop won't be able to surf the web.
Earlier, when you said you 'reset' the Hub One, did you actually logged into the Hub One and performed a 'factory reset', or pressed the 'reset' button on the rear of the hub with a pin? Or did you mean to say you just turned the hub off and on using the power button ?
Have you joined Plusnet only recently?
The Hub One should have retrieved your account username and password automatically, but it hasn't. Your account 'might' not be set up correctly.
