Internet Explorer vs. Firefox
- Internet Explorer vs. Firefox
14-01-2009 12:17 PM
After the recent security issue with IE, I downloaded Firefox and have been trying it out most of the time in preference to using IE. However, I'm not certain I have got any preferences or options set up in Firefox for optimum use. For instance, on some sites I get a blue lego brick graphic which suggests that I have not installed a plugin needed to display the image properly. So I'm looking for advice on which plugins are must haves or most useful. Also, are there any to avoid?
Will adding these plugins slow down the browser operation? I have already noticed that some sites I regularly visit seem to take longer to display in Firefox compared to IE.
Re: Internet Explorer vs. Firefox
14-01-2009 12:41 PM
14-01-2009 12:52 PM
14-01-2009 12:57 PM
Most of them were recommended from various sources, friends,blogs, forums etc.
Firefox will normally offer you plug ins where required eg correct web page display.
Getting Firefox set up will take some with trial and error. Decide what you want from the browser and try the relevant addons.
For example I use eBay often so I have installed the eBay companion.
If you try an add on and you don't like it you can disable it or uninstall it very easily
Have a look at Opera and Google Chrome if you want a faster browser.
[Edit] Here is my list using Infolister addon which I have just installed. Thanks jelv
Extensions (enabled: 30, disabled: 1; total: 31)
- Adblock Plus 1.0.1
- Add to Search Bar 1.7
- All-in-One Sidebar 0.7.8
- Better Gmail 2 0.7.2
- British English Dictionary 1.19
- ColorfulTabs 3.8
- CoolPreviews 2.7
- Firefox Companion for eBay 1.6.6
- FireFTP 1.0.3
- FoxClocks 2.5.11
- FoxLingo 2.3.2
- Foxmarks Bookmark Synchronizer 2.6.0
- GooglePreview 3.16
- Greasemonkey 0.8.20080609.0
- GUtil! 2.3.3
- IE View 1.4
- InfoLister 0.10
- Java Console 6.0.07
- Java Console 6.0.04
- Java Quick Starter 1.0
- Map+ 1.2
- NewsFox 1.0.4.1
- NoScript 1.8.8.8
- Organize Status Bar 0.6.2
- Screen grab! 0.95
- StumbleUpon 3.28
- Stylish 0.5.8
- TorrentBar 0.9.1.8
- WebMail Notifier 1.1.7
- Wizz RSS News Reader 3.0.0.3
- YubNub Command Line 0.4.2 [disabled]
14-01-2009 1:13 PM
14-01-2009 1:41 PM
The must-have is Adblock Plus which blocks advertisements, particularly the animated/video types which use up bandwidth.
Another good one is Foxmarks which backs up your bookmarks and makes them accessible on any computer with FF installed.
Reminderfox is handy to put it your appointments and to dos.
Fairly recently I have been using NoScript which adds security to the browser. However, this does take a bit of getting used to as some sites are not fully functional so you have to right-click and temporarily allow scripts. When you are paying for items/services, it is necessary to allow the site first as the software on secure sites cannot operate correctly without certain scripts.
Opening another tab in FF is easy - just press the scroll wheel and it will open the desired page in another tab.
On the Tools/Privacy tab I have it set not to allow third-party cookies and they are kept only until I close FF, although you can keep them until they expire.
The plugins that you refer to are usually installed quickly and easily - the incidence of you getting the messages will obviously decrease over time.
IMO a much safer and user-friendly browser.
14-01-2009 3:30 PM
Extensions (enabled: 29, disabled: 1; total: 30)
- AVG Safe Search 8.0 [disabled]
- AVG Security Toolbar 2.0.20080718
- ChatZilla 0.9.84
- Copy Plain Text 0.3.3
- Download Statusbar 0.9.6.3
- Fasterfox 3.0.3
- FEBE 6.0.3
- Firebug 1.3.0
- FireFTP 1.0.3
- FlashGot 1.1.7.2
- IE Tab 1.5.20081203
- InfoLister 0.10
- Java Console 6.0.10
- Java Console 6.0.11
- JavaScript Debugger 0.9.87.4
- Microsoft .NET Framework Assistant 1.0
- OPIE 1.2.2
- PageZoom 0.4.0
- PDF Download 2.1.0.0
- Print/Print Preview 0.6
- Screen grab! 0.95
- Style Sheet Chooser II 3.0.0.1
- Tab Mix Plus 0.3.7pre.080920
- URL Link 2.02.3
- User Agent Switcher 0.6.11
- Window Resizer 1.0
This list was generated (with all the BBCode) by the InfoLister addon.
14-01-2009 3:33 PM
14-01-2009 4:01 PM
14-01-2009 4:43 PM
Now I am going to have a look at a few of those on your list jelv.
14-01-2009 9:31 PM
Quote Have used FF for a very long time and never use IE7 unless I really have to (BT speedtester being one instance).
Have you tried pointing Firefox at http://217.35.209.142/ ? Works for me.
15-01-2009 8:13 AM
I now use SeaMonkey. It's mozilla based but its far lighter on memory and I've only had it ever crash once - with over 25 tabs! (and that was down to excessive flash player usage). In all SM is definitely the best browser I've used so far.
15-01-2009 8:41 AM
15-01-2009 9:35 AM
Reading all the helpful responses last night left me no time to try any changes. I did manage to download Adobe Flash player (needed for the IKEA site - don't ask!). Then spent some time trying to book airport parking. Pages took ages to load (tried a few links from the google search results), but not due to any connection problems as the router lights were not flashing. Switched to IE and pages came up with no significant delay.
If Firefox continues to perform like this I might need to try alternatives. Others I have spoken to rave about Firefox though, so I will persevere in case I have some rogue settings which cause it to perform this way.
Again thanks for all the advice, much appreciated.
15-01-2009 11:04 AM
Most people just go with the majority to be honest because they find it easier. People are like sheep - they can't think or try out new things for themselves.
I (as stated earlier) use seamonkey. Great browser and I've not looked back since. Its far lighter on memory requirements too.
