Intermittent keyboard 'not responding' issue
rogermhunt
Re: Intermittent keyboard 'not responding' issue
@Champnet @jab1   Thanks. I've downloaded it and got it running. When the problem arise again, I'll take a look and try to figure what's going on and if possible, I'll take a screen print and post it here.
@rogermhunt
when you get slow keyboard response I take it you're doing something online?
Try something like notepad to see of the keyboard works when you think it is not responding, also are you using any cloud services or NAS drive to save data as those connections could cause some slowness.
Dan
