Network Topology
Casique
Network Topology
Is it possible that anyone can answer my query please. Can anyone recommend a Plusnet or any software product that will identify my Broadband Network Topology?
PS In my loft I have a Data Cabinet with three Network switches. One is PoE. In my  home from my loft I have 4-port shutters to five rooms. I have lots of devices connected.
Thank you to anyone that replies.
10 REPLIES 10
Re: Network Topology
@Casique welcome to the forum.
You have not mentioned which Hub you are using.
For both the Hub One and Two it is possible to see what hostname and IP Addresses are connected to the LAN ports
For the Hub One from the home page >Advanced settings >Home network >Devices
For the Hub Two from the home page >My Devices >Select the port you want to list the devices.
HTH
Casique
I am using hub 2. I have been a BT user since 1978. When a BT user they had software that would show the topology of each device with a graphic representing if a PC, Camera or any other device. It occurred to me that Plusnet a subsidiary of BT must have similar software. I just cannot find it.
This is as good as it gets with a Hub two
As I said previously if you click on the port number, 2.4GHz or 5GHz you will get a list of the devices for that connection.
If you click on Plus Hub it will list out all devices connected to your Hub.
It is possible to export a list of all device connected to your Hub here as a CSV file
If the icon is incorrect it can be corrected, click the device to correct.
HTH
Fixes: 479
@Casique
Go to Advanced Settings/My Network. Select a device on the list, you will see Device Icon. Select this and you have a range of icons to pick from. Select one and select set. This is the same as you get on BT Smarthubs. You can also add a specific name for each device.
To find out which device you have then switch each off in turn and see which goes off line. You can then update this page.
Fixes: 1,495
Moderators Note
This topic has been moved from Broadband to Tech Help
Casique
I found the Installation DISK from when I was a BT Customer. It is Marked "BT Business Broadband installation CD". Does anyone here know if Plus Net have a similar current CD?
Fixes: 384
PN have never had CD media for installation.
@Casique
What more are you looking for that the Hub two currently provides?
Casique
Something that I know is better suited to my requirements than is currently supplied by the HUB 2.
I suggest an internet search to see what options are available, plusnet do not offer what you are looking for.
