ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
- ISP PlusNet Launch Faster Hub Zero 2704n Broadband...
Re: ISP PlusNet Launch Faster Hub Zero 2704n Broadband Router
18-02-2015 11:02 AM
It has it's bugs yes, but it's a budget modem/router and as such it ain't that bad.
I'm glad one user thinks the 2704n appears to be better, I look forward to other users experiences in due course, especially from those that can give more constructive detailed comparisons.
18-02-2015 5:25 PM
So, first impressions - it has wall screw mounting holes, but these are impossible to use with any LAN cables in - it does have a right angle power thingy.
And secondly, the dumbed down firmware has a nice and easy option to switch to OpenDNS (good) but no option to fix client IP addresses - or am I missing something
(sorry if already been raised - I will read the backlog sometime, promise)
18-02-2015 5:32 PM
I think that the superuser login allows that http://community.plus.net/forum/index.php/topic,135846.msg1197376.html#msg1197376 but I agree it was a silly omission
18-02-2015 5:40 PM
No fix though for the lack of wall mountability?
18-02-2015 5:50 PM
a 90 deg connector
a hole in the wall
18-02-2015 6:17 PM
Just looked at the price of them - a hole in the wall it is then
19-02-2015 11:49 AM
you can either buy some sticky back foam pads or just cut some up and use a bit of sticky tape to hold them in place (I used four bits of a high density foam block and a bit of double sided sticky tape) since you don't want it wobbling on the screw heads I placed my "mod" on my router over the existing feet just to give it that little bit extra room, oddly since there is an air vent on the bottom of the router it also made it more stable in daily operation
19-02-2015 11:55 AM
To add spacers with enough room to insert a standard RJ45 plug with the wire tightly bent would require 1.5" to 2" spacers depending on the plug
19-02-2015 12:13 PM
I'll experiment.
There's no reason why I can't put the router at the end of the 7 m lan cable that current attaches PC to router is there?
19-02-2015 12:18 PM
19-02-2015 12:41 PM
19-02-2015 12:57 PM
I used to have one at the last house mounted on the stair wall (just proud of the alcove) poor wifi all round the house, even if bedroom /lounge doors were open, that place was a quick up concrete prefab with more daylight/air gaps than solid corners....
on the other hand I have currently got perfect wifi all round the house having my router located in one corner of the lounge even when the doors are closed the signal gets to the 3rd floor rooms without issue, but in fairness the walls here are filled with those foam blocks that have silver paper on the one side to reflect the heat back into the building instead of letting it escape out,
so perhaps the signal is getting reflected back as well instead of being lost through the walls (I cant pick up the wifi unless I'm stood in front of a window when outside) of course that could be down to the fact his is a timber framed brick clad "eco house" even the roof tiles are composite materials ....
19-02-2015 1:16 PM
19-02-2015 1:22 PM
As for standing up, yeah it's a bit wobbly with 4 cables in.
19-02-2015 2:40 PM
Ok what are the best optimised settings for this router so I can start tweaking?
Also cant see a option to change the router password Huh?
