IE 11 corrupt
- IE 11 corrupt
IE 11 corrupt
06-03-2014 6:51 AM
My Internet explorer (11) win 7 64 bit is somehow corrupt, I've been through the processes recommend by MS, downloaded the latest version tried to install and get the following message
I'm open to suggestions (this not intended to be a thread to show the benefits of Opera, Firefox or Chrome)
Quote setup cannot continue because a more recent version of internet explorer is installed on your computer
4 REPLIES 4
Re: IE 11 corrupt
06-03-2014 8:07 AM
In what way is it corrupt?
Are you able to launch the browser at all?
Re: IE 11 corrupt
06-03-2014 9:43 AM
As it was an update - uninstall the update which will take you back to IE10
Re: IE 11 corrupt
06-03-2014 9:50 AM
First course of I would take would be to set IE11 back to its defaults.
Control Panel > Internet Options > Advanced Tab > Reset > Tick Delete Personal Settings > Reset
Re: IE 11 corrupt
06-03-2014 3:53 PM
Thanks guys, tried several things finally followed Oldjim's advice and rolled back the patch, working again
