How to allocate fixed DHCP Addresses in Hub Two
Seneca
Re: How to allocate fixed DHCP Addresses in Hub Two
Thanks for coming back to me but I’m definitely logged in. Most of the buttons work (eg changing the icon), but this one is greyed out.
@Baldrick1
The likely cause of this issue is when the DHCP server of the Hub Two did not issue the devices IP Address.
So the device either had an IP address allocated from another DHCP server or the device has been configured with a fixed IP Address using its Network settings.
