How do I view Sync Issues in Outlook 365 classic?
IMM
In the past, the folder pane has included a folder "Sync Issues" - which, as you would expect, contained information about any issues Outlook had with syncing to the mail server.
If I check the data file properties and folder size, I can still see the sync issues folder with a size of 725kB. however I can't seem to find a way of opening it and looking at the information.
Has anybody got any suggestions / instructions as to how to see it?
I'm looking because Outlook seems slow to download my new emails (even though gmail on my phone collects them).
Ian
3 REPLIES 3
Gel
Champion
Fixes: 29
Re: How do I view Sync Issues in Outlook 365 classic?
Have you not got Outlook app installed, in either POP3 or IMAP?; you still get sync issue folder there.
Incidentally G Mail will cease to poll other [non GOOGLE], accounts from 1/26.
IMM
Thanks,
I eventually found the "Folders" icon in amongst the "More Apps" button on the left hand side of the screen.
IMM
@Gel said "Incidentally G Mail will cease to poll other [non GOOGLE], accounts from 1/26"
Is that all other account types or just POP?
