Hot CPU is hot..
- Hot CPU is hot..
- « Previous
- Next »
Re: Hot CPU is hot..
08-08-2013 12:31 AM
Quote from: 30FTTC06 While we are on the subject, which 1 do i go for, they both look the same to me
i'm in no need of pretty lights.
http://www.scan.co.uk/search.aspx?q=Enermax+ETS-T40
i've had to clean the cpu fan out for running at 85 twice already.
Maybe you should get summin with a bit more oomph for over-clocking, maybe this.. http://www.scan.co.uk/products/thermaltake-clw0217-water-20-extreme-all-in-one-liquid-cooling-system...
and I have one of these and I have no problem with heat. http://www.scan.co.uk/products/silverstone-he01-heligon-cpu-cooler-6-heat-pipes-and-140mm-silent-fan...;
08-08-2013 10:07 PM
I will have one of these in a few days time http://www.vortez.net/articles_pages/alpenfoehn_matterhorn_pure_cpu_cooler_review,1.html ;
lets hope it fits.....
- « Previous
- Next »
