Hot CPU is hot..
- Hot CPU is hot..
Re: Hot CPU is hot..
15-07-2013 9:32 PM
15-07-2013 10:00 PM
15-07-2013 10:12 PM
15-07-2013 10:29 PM
16-07-2013 6:51 AM
i have gained 26%
16-07-2013 3:55 PM
I just clocked my memory from 1600MHz to 1866MHz, I can't see it will make much difference but if I can do it, why not.
16-07-2013 6:38 PM
16-07-2013 8:15 PM
PS my GFX card is already above stock by 10% but thats enough for now , will let it run a few weeks now .
windows Experiance has gone up from 7.1 to 7.3 ,, but win experience isnt a lot
16-07-2013 8:58 PM
16-07-2013 10:17 PM
Wait until the Winter.
01-08-2013 7:16 PM
just going to run on stock speeds for a while to compare to the old 4100
04-08-2013 8:31 AM
07-08-2013 5:53 PM
07-08-2013 6:34 PM
i'm in no need of pretty lights.
http://www.scan.co.uk/search.aspx?q=Enermax+ETS-T40
i've had to clean the cpu fan out for running at 85 twice already.
Maybe you should get summin with a bit more oomph for over-clocking, maybe this.. http://www.scan.co.uk/products/thermaltake-clw0217-water-20-extreme-all-in-one-liquid-cooling-system...
07-08-2013 9:47 PM
