HomeGroup
jrilton
HomeGroup
Hi
Sorry if this has been asked before, I've had a search and can't really find the answer.
I have a PC and a laptop connected over wifi, both running windows 10, and I want to set up a homegroup. I have set it up on my PC but my laptop keeps saying no homegroup detected. Is there a setting in the router I need to change? I used the troubleshoot but it says its a network issue. I'm sure its super simple but I'm struggling to work it out. I have the new router Hub Zero thing with the pink feet.
Thanks for any help  Tongue
nanotm
Re: HomeGroup
have you got both machines using a private network and enabled network discovery and file/printer sharing on them ?
also are they both setup to be on the same workgroup and is the router on the same workgroup ?
jrilton
Re: HomeGroup
Thanks for the reply, i just tried it again and it just worked.  Wink
