Help in setting up OpenWRT on HomeHub 5a, with static IP on fibre broadband
boodysaspie
I've edited the WAN and DSL settings as shown in the attached screenshots but I still don't get a connection. Help gratefully received.
1 REPLY 1
Fixes: 433
Re: Help in setting up OpenWRT on HomeHub 5a, with static IP on fibre broadband
@boodysaspie  your wan configuration should be PPPoE not static ip.
The ip is still allocated by plusnet, even with a static ip, it just always allocates the same one.
