Help in setting up OpenWRT on HomeHub 5a, with static IP on fibre broadband
- Help in setting up OpenWRT on HomeHub 5a, with sta...
21-11-2019 10:24 PM
I've edited the WAN and DSL settings as shown in the attached screenshots but I still don't get a connection. Help gratefully received.
1 REPLY 1
Re: Help in setting up OpenWRT on HomeHub 5a, with static IP on fibre broadband
22-11-2019 8:54 AM
@boodysaspie your wan configuration should be PPPoE not static ip.
The ip is still allocated by plusnet, even with a static ip, it just always allocates the same one.
