Master socket front plate question
- Master socket front plate question
18-11-2019 8:01 PM
Hi - I'm looking to replace the front plate which is part of an old BT box.
At the moment there are lots of wires connected to the plate, but I have no idea what they are for.
Do I have to connect the wires onto a new front plate?
Also any ideas where I can find a replacement from? I don't want to have to replace the entire box!
Many Thanks
Re: Master socket front plate question
18-11-2019 8:47 PM
It looks as if there is one extension wired into the front plate - the white/blue and blue/white pair. If you want that extension to continue to work you will need to connect those wires into any new front plate you install.
The white/red and red/white pair do not appear to be connected and so you should not connect those to any new front plate.
18-11-2019 9:38 PM
I would suggest that you fit a filtered faceplate such as one of these. https://www.amazon.co.uk/Solwise-ADSL-VDSLFACE-SOL-Filtered-Compliant-Faceplate/dp/B00NBZKN30/ref=sr...
After fitting it you no longer need to use micro filters. If you want to use the extension then the pair of blue/white cables only should be connected. The terminals to use will be identified on the instructions that come with the filtered faceplate..
18-11-2019 10:18 PM
You should use some photo editing s/ware to reduce size of images posted!
18-11-2019 10:33 PM - edited 18-11-2019 10:34 PM
It seems odd that the forum rules limit the size of avatars and signatures to 40kB, but attached files can be up to 21MB - all nine of them. ‼️
Maximum files per post: 9
Maximum size per file: 21MB
Accepted filetypes: jpg,gif,png,jpeg,pdf,csv,txt,doc
FTTC 40/10 Billion 8800NL
BT technician (Retired)
19-11-2019 12:12 AM
Thread moved from Home Phone to Tech Help.
Forum Moderator and Customer
23-11-2019 2:20 PM
The white/blue & blue/white pair are an extension or extensions from the BT master socket.
I also strongly recommend a filtered faceplate and connecting your router to that.
The white/orange and orange/white can be a bell wire and (generally not used) earth. If extensions ring you either have a socket elesewhere with the required capacitor or relatively modern phones that don’t need a primary socket.
All in all, if it works at present leave the wiring as is.
