Hello, Why as my pc developed over 2775 errors ?
- Re: Hello, Why as my pc developed over 2775 errors...
29-08-2012 7:58 AM
Im a complete novice to pc,s , Can any body help ? thankyou , P Rich.
3 REPLIES 3
Re: Hello, Why as my pc developed over 2775 errors ?
29-08-2012 8:39 AM
Welcome to the forum
You may need to be a little more specific as to where you are seeing these errors.
29-08-2012 2:10 PM
If you're seeing this on the web, then just ignore it as it's probably just a scam.
That's RPM to you!!
30-08-2012 11:47 PM
I'm curious. Have you had a phone call recently advising you of the errors?
There are some scam calls around supposedly from Microsoft. On these calls you are directed to the Event Viewer which may show some system errors (Nothing to worry about really).
If this is what you're referring to, I wouldn't worry about it too much.
P.S: If you do not any calls DO NOT allow remote access to your computer.
