Hello, Why as my pc developed over 2775 errors ?
stuartjanet123
Im a complete novice to pc,s , Can any body help ? thankyou , P Rich.
3 REPLIES 3
Strat
Fixes: 565
Re: Hello, Why as my pc developed over 2775 errors ?
Welcome to the forum Smiley
You may need to be a little more specific as to where you are seeing these errors.
RPMozley
Fixes: 13
If you're seeing this on the web, then just ignore it as it's probably just a scam.
That's RPM to you!!
Pettitto
Fixes: 5
I'm curious. Have you had a phone call recently advising you of the errors?
There are some scam calls around supposedly from Microsoft. On these calls you are directed to the Event Viewer which may show some system errors (Nothing to worry about really).
If this is what you're referring to, I wouldn't worry about it too much.
P.S: If you do not any calls DO NOT allow remote access to your computer.
