Hardly tec and a bit phony
Luzern
Fixes: 9
I have a set of Panny Dects. There's an indentation on the rear aid sliding off the battery cover. Trouble is I just cant budge it, may be because my strength is waning due to age.( ninth decade).
Any helpful ideas, please, out there?
21 REPLIES 21
RobPN
Fixes: 13
Re: Hardly tec and a bit phony
Any chance of a photo of the offending item?
shutter
Fixes: 65
@Luzern   Maybe..... Presss down on the battery cover, then slide it off .... ?
Shep41
Seasoned Pro
Fixes: 6
Do you have an hammer😂
VileReynard
Fixes: 20
Try a rubber glove.
shutter
Fixes: 65
@Luzern  have you solved this problem ?
Luzern
Fixes: 9
Today and tomorrow are not days for considering or finding solutions to problems, if you've ever experienced Moviprep. I don't know, if I want to watch a snake in My TubeFunny
VileReynard
Fixes: 20
Do you speak of tapeworms? Funny
RobPN
Fixes: 13
Perhaps @Luzern speaks with a forked tongue.  Smiley
Luzern
Fixes: 9
@VileReynard Somewhat bigger than a tapeworm, and definitely appropriate for use of a renowned Cpl Jones comment on the Fuzzies.
@RobPN I could suggest effect sounds like forked bum.
Luzern
Fixes: 9
Back to normal now, and that's medical concerns too, here are my response to suggestions made by you all. No luck so far.
@RobPN
Pics now attached
@shutterPerhaps my strength is waningSad, but no luck with that.
@Shep41. A bit drastic. I think.Grin
@VileReynardThat doesn’t work either. Or are you suggesting a lubricated one for insertion somewhere?Shocked
RobPN
Fixes: 13
@Luzern
As suspected, it looks almost certainly to be the type to which you need to apply pressure whilst simultaneously performing a sliding motion as described by @shutter, possibly wearing a rubber glove as suggested by @VileReynard for better grip if necessary.
Apologies if you think I'm stating the obvious, but the pressure point is where the arrow symbol is, and the direction of pressure is from the surface towards the innards of the phone (e.g. as if you were pressing your belly button towards your innards).  It may be easier using both thumbs if you don't have the strength in one.
If you still can't do it, may I suggest asking a friend/relative/neighbour?  Wink
Edit; typo
And may I suggest that if you still can't get it undone smash it to pieces the catharsis alone will be worth it.
JayG
Fixes: 6
Looks like it should just slide out downwards - should be easy.
is it possible that you've upset someone who then perchance added a spot or two of superglue as a delayed gratification revenge tactic? Knuppel
Luzern
Fixes: 9
@Anonymous Catharsis is causing me to think "telephonus panasonici delenda est!"
@ anyone OT
I know phones last for ages, but since I bought mine have any substantial improvements been made?
And now to my tribe to deal with.
