HG612 & OPNSense Firewall
JRIrish
Re: HG612 & OPNSense Firewall
There is one thing you learn very quickly with both pfSense and OPNsense, each and every time you make a configuration change make a backup! Believe me it makes life a hell of a lot easier! Diagnostics-Backup & Restore.
OsoPolar
HI
I need a little more guidance please
I have my OPNsense box with the PPPoE credentials connection and works fine and connected to LAN1.
I converted my wifi router R7800 DD-WRT into a WAP with guidance from the DD-WRT devs.
But when i pop it into my switch i get no wifi whatever i try.
But if i shove the wifi router in LAN of the modem everything is fine?
What am i doing wrong?
Fixes: 585
Sounds like the r7800 is still configured as a router and not a WAP.
OsoPolar
OsoPolar
OsoPolar
When i say LAN i mean LAN2 port i still have OPNsense in LAN 1 on the modem
Rockyuk
I can see you have disabled the DHCP server. So how is it assigning IP's on the network? Are you manually assigning the endpoints? Computers, phones and laptops etc? Have you tried it with it on?
Rockyuk
So, your setup should look like this
Modem (Internet) - OPNSense (Dual Nic) - Switch or Hub and then your WAP?
OsoPolar
HI
I was under the impression with LAN & WAN being in OPNsesne it controls the issue of IP addresses it is the master DNS server otherwise you would have 2 ?
Rockyuk
I have a Mesh WAP attached to my switch which get internet access from my Pfsense. But I have given it a different IP address on the network and it is running DHCP as well.
Basically I have segregated the Pfsense and Mesh WAP from eachother so they work in harmony.
Fixes: 585
@OsoPolar well you certainly don't want gateway mode!
According to this https://wiki.dd-wrt.com/wiki/index.php/Wireless_Access_Point it should be in router mode with WAN and dhcp disabled
OsoPolar
HI
Yes i was aware of this but from a senior Dev on DD-WRT i received this message
There is a wiki: https://wiki.dd-wrt.com/wiki/index.php/Wireless_access_point
But IMHO opinion that is somewhat flawed.
I do it like this:
Wireless Access Point (WAP):
A secondary router connected wired LAN<>LAN on the same subnet as the primary router.
On Basic Setup page:
• On Basic Setup page:
o WAN disabled
o DHCP server Disabled (=off and NOT set as Forwarder!)
o Local IP address in subnet of primary router but outside DHCP scope, make sure the used IP address is unique on your network you cannot have duplicates.
o Gateway and Local DNS pointing to primary router
• Keep DNSMasq enabled (both on Basic Setup page and Services page)
• On Setup > Advanced Routing, keep Operating mode in the default Gateway (the wiki says Router mode but do not do that, either it does not matter (this case) or break things)
• On Security > Firewall keep the SPI Firewall enabled, although you do not want a firewall it will be automatically disabled as there is no WAN so no need to change this setting form default.
• Connect LAN <> LAN (do not use the WAN port unless you really need that extra port, for most routers traffic still must use the CPU so performance is lacklustre and there are some routers where the WAN port is not added to the br0 so the WAN port could be non-functional on some routers).
Note: for Broadcom routers for best throughput enable CTF on Basic Setup Page
You have to add the following rule to the firewall in order to get internet access from clients attached to a VAP/Bridge on your WAP.
In the web-interface of the router (the WAP): Administration > Commands save Firewall:
#Always necessary (alternatively set static route on main router and NAT traffic from VAP/Bridge out via WAN):
iptables -t nat -I POSTROUTING -o br0 -j SNAT --to $(nvram get lan_ipaddr)
If you want to only have the VAP/bridge to have internet access and not access to the rest of the network
#Replace with the appropriate interface of your VAP, e.g. wl0.1, wlan0.1 etc:
GUEST_IF="wlan1.1"
#Net Isolation does not work on a WAP so keep it disabled, add for isolating VAP from main network:
iptables -I FORWARD -i $GUEST_IF -d $(nvram get lan_ipaddr)/$(nvram get lan_netmask) -m state --state NEW -j REJECT
#For isolating the WAP itself from the VAP/bridge:
iptables -I INPUT -i $GUEST_IF -m state --state NEW -j REJECT
iptables -I INPUT -i $GUEST_IF -p udp --dport 67 -j ACCEPT
iptables -I INPUT -i $GUEST_IF -p udp --dport 53 -j ACCEPT
iptables -I INPUT -i $GUEST_IF -p tcp --dport 53 -j ACCEPT​
Fixes: 585
@OsoPolar as long as you are connecting LAN to LAN  then it shouldn't matter. It should basically be , allocate it an ip in the main router subnet and disable dhcp and wan
OsoPolar
SO you saying i should try it in modem mode?
Fixes: 585
It ( r7800) doesn't have a modem mode.
Connect the r7800 via one of its lan ports to a lan port on the opnsense. Disable dhcp on the r7800.
