Hub 2 with Sky wifi extenders
IanH7
New customer to PlusNet. Not a techie.
Common problem of poor signal in outlying rooms from where the router is positioned.
Sky fixed it by providing wifi extenders and I wondered if I could use one of these (I have to return one to Sky) with my Plus Net router?
I have done a factory reset on the extender and clicked on the WPS buttons on the extender and router.
All three lights are on on the Sky extender but it has made no difference.
Any ideas, other than buying a new extender? If so, any suggestions?
Thanks for any advice.
1 REPLY 1
Fixes: 476
Re: Hub 2 with Sky wifi extenders
Moderator's Note
This topic has been moved from Broadband to Tech Help
