FF 44.0.2 and volume changes
Mav
Fixes: 515
Since installing the latest version of FF I have noticed that if there is audio playing one or more tabs then the volume of other players such as VLC or Winamp is reduced for the duration then returned back to normal when the audio in FF is stopped or paused.
This can be helpful but not always wanted but I can't find an option to stop this happenning.
It doesn't happen in Chrome or IE (latest vesions)
Forum Moderator and Customer
2 REPLIES 2
rongtw
Fixes: 12
Re: FF 44.0.2 and volume changes
Mav there is a problem with FF44 causing sound problems  Roll_eyes since first FF44 came out i can no longer play any sound in 5.1 only in stereo  Crazy
Have been on their help support forum , they are aware of some sound problems and are working on it  Wink
Mav
Fixes: 515
Cheers.
But I wonder what I am experiencing is deliberate. Does anyone else have the same issue?
