Excel column identities
- Excel column identities
an hour ago
All of a sudden, any new Excel files have the columns identified with numbers instead of letters - for example R4C7. The older Excel files aren't affected by this - they still identify each cell such as D7.
I haven't been able to find the way back to the older IDs. Does anyone know the cause and the solution, please?
Thankyou
1 REPLY 1
Re: Excel column identities
38 minutes ago
"R1C1 reference style" is enabled for formulas.
File >> Options >> Formulas >> R1C1 reference style ( tick to enable / clear to disable )
