Unifi UDM Pro problems with Internet
Peter_Kelly
Hi, I have Fibre to Cabinet and broadband from Plusnet.  I have the Unifi UDM Pro system to overcome WiFi issues in our house and the coverage is good as a result.  However, the UDM Pro connects to the master socket via an Openreach modem and this may be the cause of my Internet problems.  When the Plusnet service drops and then reconnects, it seems to upset the modem and although the broadband is restored I have no Internet access.  I have to reboot the modem to restore normal service.  Suggested solutions so far are to:
1. replace the modem in case it is faulty or
2. use the Plusnet Hub Two supplied by Plusnet in Bridge mode to ensure compatibility.
If anyone has anything to offer I will be most grateful!
Best regards,
Peter.
1 REPLY 1
Fixes: 585
Re: Unifi UDM Pro problems with Internet
@Peter_Kelly
I'd start by trying the Hub 2 in bridge mode. That should confirm whether the problem is the old modem or something else.
