Excel column identities
penneck
All of a sudden, any new Excel files have the columns identified with numbers instead of letters - for example R4C7. The older Excel files aren't affected by this - they still identify each cell such as D7.
I haven't been able to find the way back to the older IDs. Does anyone know the cause and the solution, please?
Thankyou
2 REPLIES 2
PhilipHeyes
Seasoned Champion
Fixes: 28
Re: Excel column identities
"R1C1 reference style"   is enabled for formulas.
File >> Options >> Formulas >> R1C1 reference style ( tick to enable / clear to disable )
penneck
Thankyou @PhilipHeyes   that did the trick. It was well hidden though, and doesn't explain why it got set in the first place.
All the best
