Embedded <audio/> in HTML page not working online.
FIXED- Subscribe to RSS Feed
- Re: Embedded <audio/> in HTML page not working on...
07-06-2019 3:41 PM
Hello there
I've just added a simple audio file into a webpage hosted on my Plusnet webspace and while everything works well on my local machine but when I FTP (using Filezilla) the sound no longer works (on any browser). The total added code is
<iframe src="silence.mp3" allow="autoplay" id="audio" style="display:none"></iframe>
<audio id="player" autoplay>
<source src="duke.mp3" type="audio/mp3">
</audio>
The first part just allows Chrome to autoplay the next part.
Any thoughts on why it doesn't work when online would be gratefully received!
Michael
Fixed! Go to the fix.
Re: Embedded <audio/> in HTML page not working online.
07-06-2019 3:47 PM
Hi @mpw Welcome to the Forums. It could be that the file can't be found so you might want to set the path of the mp3 file to
./duke.mp3
or provide it with a full path from the server root.
07-06-2019 3:58 PM
Hello there,
Thanks for the prompt reply!
I've checked and on both my local machine and also on my webspace that the files are just within the same single folder so I didn't think that I'd need a path.
Michael
07-06-2019 4:24 PM - edited 07-06-2019 4:27 PM
OK @mpw, but humour me if you will and prepend the file name with
Also remember that the server will no doubt be Unix so case is an issue as well, so duke.mp3 is not the same as Duke.mp3
07-06-2019 5:18 PM
Sir - you are a genius!!
Thank you so much for taking the time to help - I had upper case 'Duke' locally which worked fine but it was looking for lower case when it was online.
Thanks again for your assistance!
Regards
Michael
08-06-2019 10:34 AM
You are more than welcome @mpw, if you need any further assistance we're a friendly bunch here and only too willing to help.
11-06-2019 12:46 AM
You'd be surprised! File paths are a total menace at times and being a simple / boring thing not many pay much attention to them but the simple / and ./ can mean two big differences.
17-06-2019 12:34 AM
Just about all web servers run Linux, and Linux is case-sensitive. You could even have Duke.mp3 and duke.mp3 as different files. Only Windows is so carefree about filenames 🙂
17-06-2019 3:59 PM
Due to its DOS origins.
