Thunderbirding mad!
FIXED- Subscribe to RSS Feed
- Thunderbirding mad!
18-06-2019 4:06 PM
I'm in a fix. My side panel with my various accounts's folders has suddenly gone walkies, so I am unable to search fot expected incoming mail. To exacerbate matters my Mozilla forum identity log on no longer works, and, attempting tor re-register, although I answer the question, "how many letters does Mozilla have:?", the process fails.
Any ideas for my problems, please, guys?
Fixed! Go to the fix.
Re: Thunderbirding mad!
18-06-2019 5:08 PM
18-06-2019 5:15 PM
A wild one, @Luzern - have you inadvertently somehow 'hidden' it? Check you have something like this set in your 'View' menu: 'Classic' - with a dot, 'Folder pane' & 'Folder pane columns' with a tick - the column option is not essential if you haven't got it - just give you more options.
I would have done a screenshot, but the 'Snipping Tool' doesn't seem to play nice with non-MS applications.
18-06-2019 6:24 PM
18-06-2019 6:27 PM
@Luzern - No, try the 'View' menu on the left top.
18-06-2019 7:35 PM
Picture of what I meant:
18-06-2019 8:03 PM
@jab1 Doh! Coulombs now seen, but one account still with red striped and cannot be viewed. I shall ahe to remove and re-install it.
18-06-2019 8:12 PM
If the menus referred to ny @jab1 are not showing, right-click on the 'Title Bar' and check 'Menu Bar'.
If another profile is in use you may find this help article useful to start TB with your regular profile.
19-06-2019 12:37 PM
It was me, no doubt, getting nowhere. Viewing messages was hopeless, because there were red-white stripes hiding the texts. On a whim I opted to open in new window, and they were visible. Finally, in desperation, I uninstalled TB, and downloaded the program anew. It now works.
What the dickens had happened to cause my trouble, but now all is as it should be.
Thanks all.
19-06-2019 12:40 PM
Glad you're sorted, @Luzern - I was just going to ask how far you'd got when then flag popped up for your reply.
